Ir para o conteúdo principal
Blu Dash 5.0 Dual SIM Back Camera Replacement
O que você precisa
  1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: passo 1, imagem 1 %32 Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: passo 1, imagem 2 %32
    • Make sure device is disconnected and turned off.
    • Locate the groove on the bottom left corner of the back of the phone.
    • Insert the plastic opening tool into the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 2, imagem 1 %32
    • Pry the battery out using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 3, imagem 1 %32
    • Remove the 12 screws on the back panel using a J000 screwdriver.
    • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
    • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
  4. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 4, imagem 1 %32 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 4, imagem 2 %32 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 4, imagem 3 %32
    • Peel off the back panel with your hand.
    • Remove the back panel slowly to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 5, imagem 1 %32 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 5, imagem 2 %32 Blu Dash 5.0 Dual SIM Back Camera Replacement: passo 5, imagem 3 %32
    • Flip up the ZIF flap using the spudger.
    • Gently remove the ribbon cable with tweezers.
    • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
    • Remove the back camera using tweezers.
Conclusão
Mukish Kumar Munyady
Membro desde: 01/30/17
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-1, Baechle Spring 2017 Membro de IUPUI, Team 1-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 369
