Ir para o conteúdo principal
Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement
O que você precisa
  1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: passo 1, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: passo 1, imagem 2 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: passo 1, imagem 3 %32
    • Make sure the diffuser is not plugged into a socket and that there is no water or oil near or in the diffuser before beginning the guide.
    • Use a Phillips #2 screwdriver to remove the four 8 mm screws on the bottom of the diffuser.
  2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 2, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 2, imagem 2 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 2, imagem 3 %32
    • Lift the ceramic top of the oil diffuser.
    • Then lift off the plastic top off the diffuser.
  3. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 3, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 3, imagem 2 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 3, imagem 3 %32
    • Lift the last plastic lid.
    • You will see a circuit board, and there will be a cord connecting it to the circuit board.
  4. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 4, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 4, imagem 2 %32
    • Gently unplug the cord from the circuit board.
    • Place the plastic lid somewhere safe on the a flat surface.
  5. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 5, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 5, imagem 2 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 5, imagem 3 %32
    • Remove the plastic ring and place somewhere safe on a flat surface.
  6. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 6, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 6, imagem 2 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 6, imagem 3 %32
    • Remove two Truss head 4 mm screws with a Phillips #2 screwdriver and place safely nearby.
  7. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 7, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 7, imagem 2 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 7, imagem 3 %32
    • Gently lift the circuit board onto it's side
    • The white connector plugs the fan into the circuit board.
  8. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 8, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 8, imagem 2 %32
    • Unplug the white connector.
    • There are four #M1 6 mm Phillips pan head screws holding down the fan.
  9. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 9, imagem 1 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 9, imagem 2 %32 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: passo 9, imagem 3 %32
    • Remove the #M1 6 mm screws with a Phillips #2 screwdriver while holding down the fan.
    • Gently lift the fan and place the fan someplace safe on the flat surface.
Conclusão
Muniira Mohamoud
Membro desde: 01/18/22
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 47
Duração total: 610
