Introdução
This guide will show you several blade removing techniques for when the blades are stuck somewhere on the motor of your Ninja Master Prep QB900B.
Be sure to have a tough cloth or a cut resistant glove on hand for the repair. In addition, make sure to turn off the device and unplug from the power outlet before beginning this repair.
O que você precisa
To remove the blades from each other, twist both blades in opposite directions and pull.
Quase terminado!
Linha de Chegada
