Ir para o conteúdo principal
Blackstone Cascade Pro Fan Replacement
O que você precisa
  1. Blackstone Cascade Pro Fan Replacement, Fan: passo 1, imagem 1 %32 Blackstone Cascade Pro Fan Replacement, Fan: passo 1, imagem 2 %32 Blackstone Cascade Pro Fan Replacement, Fan: passo 1, imagem 3 %32
    • Remove the four screws surrounding the back of the Blackstone fan using a Phillips #00 screwdriver.
    • Remove the cover at the back of the fan.
  2. Blackstone Cascade Pro Fan Replacement: passo 2, imagem 1 %32 Blackstone Cascade Pro Fan Replacement: passo 2, imagem 2 %32
    • Remove the diamond cover at the top of the fan.
    • The diamond cover will be connected to a set of wires to the fan. Simply place the cover to the side for the rest of the repair.
  3. Blackstone Cascade Pro Fan Replacement: passo 3, imagem 1 %32 Blackstone Cascade Pro Fan Replacement: passo 3, imagem 2 %32 Blackstone Cascade Pro Fan Replacement: passo 3, imagem 3 %32
    • Remove the two screws that are holding the spherical cover shielding the main fan using a Phillips #00 screwdriver.
    • Remove the spherical cover surrounding the main fan.
  4. Blackstone Cascade Pro Fan Replacement: passo 4, imagem 1 %32 Blackstone Cascade Pro Fan Replacement: passo 4, imagem 2 %32
    • On the opposite side there will be a cover identical to the one removed in the previous step.
    • Twist the main fan to remove the cover on the opposite side.
  5. Blackstone Cascade Pro Fan Replacement: passo 5, imagem 1 %32 Blackstone Cascade Pro Fan Replacement: passo 5, imagem 2 %32 Blackstone Cascade Pro Fan Replacement: passo 5, imagem 3 %32
    • Using the socket wrench, and a size 10 shallow socket, remove the hexagon screw at the center of the main fan.
    • Pull out the main fan.
    • Depending on the age of your fan, it may require more strength to pull it out. Be careful to not use too much force.
Conclusão
Mohamed Mallah
Membro desde: 01/24/24
148 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 732
