O que você precisa
Remove front silver trim by using plastic opening tools and wiggle it off.
Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
Peel off the three ribbon cables
The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
5 outras pessoas executaram este guia.
