Ir para o conteúdo principal
Blackberry Torch 9800 Logic Board Replacement
O que você precisa
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: passo 1, imagem 1 %32 Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: passo 1, imagem 2 %32
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: passo 2, imagem 1 %32 Blackberry Torch 9800 Logic Board Replacement: passo 2, imagem 2 %32
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: passo 3, imagem 1 %32 Blackberry Torch 9800 Logic Board Replacement: passo 3, imagem 2 %32 Blackberry Torch 9800 Logic Board Replacement: passo 3, imagem 3 %32
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: passo 4, imagem 1 %32 Blackberry Torch 9800 Logic Board Replacement: passo 4, imagem 2 %32
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: passo 5, imagem 1 %32 Blackberry Torch 9800 Logic Board Replacement: passo 5, imagem 2 %32
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
Conclusão
3 outras pessoas executaram este guia.
Keegan Williams
Membro desde: 02/19/16
216 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 1-5, Garvin Spring 2016 Membro de Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 870
