Ir para o conteúdo principal
Introdução
In this guide you will learn the process to replace the battery in a Blackberry Storm 9530.
Ferramentas
Peças
Nenhum componente especificado.
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: passo 1, imagem 1 %32 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: passo 1, imagem 2 %32 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: passo 1, imagem 3 %32
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: passo 2, imagem 1 %32
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
Conclusão
melanie lim
Membro desde: 22/04/2014
607 Reputação
6 Guias de autoria
Cal Poly, Team 9-16, Regan Spring 2014 Membro de Cal Poly, Team 9-16, Regan Spring 2014
CPSU-REGAN-S14S9G16
4 Membros
10 Guias de autoria
0 Comments
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 1,448
