Ir para o conteúdo principal
Blackberry RIM 7250 Side Button Replacement
O que você precisa
  1. Blackberry RIM 7250 Side Button Replacement, Battery: passo 1, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement, Battery: passo 1, imagem 2 %32 Blackberry RIM 7250 Side Button Replacement, Battery: passo 1, imagem 3 %32
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Side Button Replacement: passo 2, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement: passo 2, imagem 2 %32 Blackberry RIM 7250 Side Button Replacement: passo 2, imagem 3 %32
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Side Button Replacement: passo 3, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement: passo 3, imagem 2 %32 Blackberry RIM 7250 Side Button Replacement: passo 3, imagem 3 %32
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Side Button Replacement, Back Housing: passo 4, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement, Back Housing: passo 4, imagem 2 %32
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Side Button Replacement: passo 5, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement: passo 5, imagem 2 %32
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Side Button Replacement: passo 6, imagem 1 %32
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Side Button Replacement: passo 7, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement: passo 7, imagem 2 %32 Blackberry RIM 7250 Side Button Replacement: passo 7, imagem 3 %32
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Side Button Replacement, Front Housing: passo 8, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement, Front Housing: passo 8, imagem 2 %32
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Side Button Replacement: passo 9, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement: passo 9, imagem 2 %32 Blackberry RIM 7250 Side Button Replacement: passo 9, imagem 3 %32
    • Pull the two pieces apart to separate the front housing from the internals.
  10. Blackberry RIM 7250 Side Button Replacement, Side Button: passo 10, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement, Side Button: passo 10, imagem 2 %32
    • Remove the single 5 mm Torx T6 screw.
  11. Blackberry RIM 7250 Side Button Replacement: passo 11, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement: passo 11, imagem 2 %32 Blackberry RIM 7250 Side Button Replacement: passo 11, imagem 3 %32
    • Grab side button housing with your thumb and index finger.
    • Remove the side button housing from the internals.
  12. Blackberry RIM 7250 Side Button Replacement: passo 12, imagem 1 %32 Blackberry RIM 7250 Side Button Replacement: passo 12, imagem 2 %32 Blackberry RIM 7250 Side Button Replacement: passo 12, imagem 3 %32
    • Hold the side button housing with one hand and hold the side button with the other.
    • Lift the side button from side button housing.
    • There will be a subtle click when the side button is detached from the side button housing.
Conclusão
Noah Eckert
Membro desde: 11/05/18
519 Reputação
Autoria de 5 guias
Equipe
IUPUI, Team S2-G4, Baechle Fall 2018 Membro de IUPUI, Team S2-G4, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G4
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 156
