Ir para o conteúdo principal
Blackberry Pearl 8100 SIM Card Replacement
  1. Blackberry Pearl 8100 SIM Card Replacement, Battery: passo 1, imagem 1 %32
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. Blackberry Pearl 8100 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32
    • Slide the larger of the two metal casings upward (in the direction pointed to as “unlock”).
  3. Blackberry Pearl 8100 SIM Card Replacement: passo 4, imagem 1 %32
    • Lift the metal casing.
    • Insert an SD Card.
Conclusão
Robert Cronin
Membro desde: 04/08/10
544 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 34-57, Forte Spring 2010 Membro de Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 9,282
