Ir para o conteúdo principal
Blackberry Curve 9300 Screen Replacement
O que você precisa
  1. Blackberry Curve 9300 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Screen Replacement: passo 2, imagem 1 %32
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Screen Replacement: passo 3, imagem 1 %32
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Screen Replacement, Keyboard: passo 4, imagem 1 %32
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Screen Replacement: passo 5, imagem 1 %32 Blackberry Curve 9300 Screen Replacement: passo 5, imagem 2 %32
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Screen Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Screen Replacement: passo 7, imagem 1 %32
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Screen Replacement: passo 8, imagem 1 %32
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Screen Replacement: passo 9, imagem 1 %32
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Screen Replacement, Screen: passo 10, imagem 1 %32
    • Locate and remove the two 5mm screws on top of keyboard base using the T6 Torx screwdriver
  11. Blackberry Curve 9300 Screen Replacement: passo 11, imagem 1 %32
    • Carefully pull the keyboard base up and away from the phone.
    • Disconnect the keyboard base from the phone completely.
  12. Blackberry Curve 9300 Screen Replacement: passo 12, imagem 1 %32 Blackberry Curve 9300 Screen Replacement: passo 12, imagem 2 %32 Blackberry Curve 9300 Screen Replacement: passo 12, imagem 3 %32
    • Locate and remove the four 5mm screws on the top and bottom of the phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Screen Replacement: passo 13, imagem 1 %32 Blackberry Curve 9300 Screen Replacement: passo 13, imagem 2 %32
    • Use a plastic opening tool to find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • The opening tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Screen Replacement: passo 14, imagem 1 %32 Blackberry Curve 9300 Screen Replacement: passo 14, imagem 2 %32
    • From the back of the phone, use a finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Screen Replacement: passo 15, imagem 1 %32 Blackberry Curve 9300 Screen Replacement: passo 15, imagem 2 %32 Blackberry Curve 9300 Screen Replacement: passo 15, imagem 3 %32
    • Use a plastic opening tool to detach the ribbon cable from the top left corner of the screen, and separate the screen from the motherboard.
Conclusão
9 outras pessoas executaram este guia.
Alek Squires
Membro desde: 09/30/13
431 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 14-7, Forte Fall 2013 Membro de Cal Poly, Team 14-7, Forte Fall 2013
CPSU-FORTE-F13S14G7
Membros da 5
Autoria de 5 guias
Um comentário
would appreciate new ldc part # and order info! - - !
Donald Burgo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 4,719
