Ir para o conteúdo principal
Blackberry Curve 8330 Battery Replacement
  1. Blackberry Curve 8330 Battery Replacement, Remove Back Cover: passo 1, imagem 1 %32
    • We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
    • Hold the phone with the back side facing you.
    • Press down on the silver tab towards the bottom end of the phone.
    • Carefully lift up the back casing to reveal the battery.
  2. Blackberry Curve 8330 Battery Replacement, Remove Battery: passo 2, imagem 1 %32
    • Put your finger on the top left corner of the battery and lift the battery up and out of its housing.
    • The phone should now look like this.
Conclusão
Uma outra pessoa concluiu este guia.
Riley McGovern
Membro desde: 04/04/12
22 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 14-11, Forte Spring 2012 Membro de Cal Poly, Team 14-11, Forte Spring 2012
CPSU-FORTE-S12S14G11
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 2,220
