Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Pull up on the top edge of the battery to remove it.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
Remove the two top screws with a T5 Torx screwdriver.
Gently pry off the side casings from the top.
You will not need to remove the sides on the bottom.
Use a plastic opening tool to detach the securing clips holding the the front panel in place.
Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
After the bottom two screws have been removed the side casings can be removed.
Uma outra pessoa concluiu este guia.
