Ir para o conteúdo principal
Blackberry Curve 8320 Speaker Replacement
O que você precisa
  1. Blackberry Curve 8320 Speaker Replacement, Battery: passo 1, imagem 1 %32 Blackberry Curve 8320 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Hold the phone with the back facing you.
    • Press the silver tab down and remove the cover.
  2. Blackberry Curve 8320 Speaker Replacement: passo 2, imagem 1 %32
    • Pull up on the top edge of the battery to remove it.
  3. Blackberry Curve 8320 Speaker Replacement, Front Panel: passo 3, imagem 1 %32 Blackberry Curve 8320 Speaker Replacement, Front Panel: passo 3, imagem 2 %32 Blackberry Curve 8320 Speaker Replacement, Front Panel: passo 3, imagem 3 %32
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  4. Blackberry Curve 8320 Speaker Replacement: passo 4, imagem 1 %32 Blackberry Curve 8320 Speaker Replacement: passo 4, imagem 2 %32
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  5. Blackberry Curve 8320 Speaker Replacement: passo 5, imagem 1 %32 Blackberry Curve 8320 Speaker Replacement: passo 5, imagem 2 %32
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  6. Blackberry Curve 8320 Speaker Replacement: passo 6, imagem 1 %32
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  7. Blackberry Curve 8320 Speaker Replacement: passo 7, imagem 1 %32
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  8. Blackberry Curve 8320 Speaker Replacement, Speaker: passo 8, imagem 1 %32 Blackberry Curve 8320 Speaker Replacement, Speaker: passo 8, imagem 2 %32 Blackberry Curve 8320 Speaker Replacement, Speaker: passo 8, imagem 3 %32
    • Use a T6 Torx screwdriver to remove the four screws located on the corners of the keyboard frame.
    • The screws are 6mm long.
  9. Blackberry Curve 8320 Speaker Replacement: passo 9, imagem 1 %32 Blackberry Curve 8320 Speaker Replacement: passo 9, imagem 2 %32
    • After the bottom two screws have been removed the side casings can be removed.
  10. Blackberry Curve 8320 Speaker Replacement: passo 10, imagem 1 %32 Blackberry Curve 8320 Speaker Replacement: passo 10, imagem 2 %32 Blackberry Curve 8320 Speaker Replacement: passo 10, imagem 3 %32
    • Remove the back case.
    • The speaker is located on the back case.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 3-6, Regan Fall 2011 Membro de Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
5 Membros
Autoria de 9 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 2,073
