Ir para o conteúdo principal
Blackberry Curve 8320 Keyboard Replacement
O que você precisa
  1. Blackberry Curve 8320 Keyboard Replacement, Front Panel: passo 1, imagem 1 %32 Blackberry Curve 8320 Keyboard Replacement, Front Panel: passo 1, imagem 2 %32 Blackberry Curve 8320 Keyboard Replacement, Front Panel: passo 1, imagem 3 %32
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  2. Blackberry Curve 8320 Keyboard Replacement: passo 2, imagem 1 %32 Blackberry Curve 8320 Keyboard Replacement: passo 2, imagem 2 %32
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  3. Blackberry Curve 8320 Keyboard Replacement: passo 3, imagem 1 %32 Blackberry Curve 8320 Keyboard Replacement: passo 3, imagem 2 %32
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  4. Blackberry Curve 8320 Keyboard Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  5. Blackberry Curve 8320 Keyboard Replacement: passo 5, imagem 1 %32
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  6. Blackberry Curve 8320 Keyboard Replacement, Keyboard: passo 6, imagem 1 %32 Blackberry Curve 8320 Keyboard Replacement, Keyboard: passo 6, imagem 2 %32
    • Remove the keyboard.
    • Be careful not to bend or fold the keyboard, as it can break easily.
Conclusão
Uma outra pessoa concluiu este guia.
Yegor Pomortsev
Membro desde: 10/12/11
123 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-6, Regan Fall 2011 Membro de Cal Poly, Team 3-6, Regan Fall 2011
CPSU-REGAN-F11S3G6
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,026
