Ir para o conteúdo principal
Blackberry Curve 8310 Screen Housing Replacement
O que você precisa
  1. Blackberry Curve 8310 Screen Housing Replacement, Battery: passo 1, imagem 1 %32
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Blackberry Curve 8310 Screen Housing Replacement: passo 2, imagem 1 %32
    • Pry from the top of the battery to pull it out.
  3. Blackberry Curve 8310 Screen Housing Replacement, Lens: passo 3, imagem 1 %32
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. Blackberry Curve 8310 Screen Housing Replacement: passo 4, imagem 1 %32
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. Blackberry Curve 8310 Screen Housing Replacement: passo 5, imagem 1 %32
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. Blackberry Curve 8310 Screen Housing Replacement: passo 6, imagem 1 %32 Blackberry Curve 8310 Screen Housing Replacement: passo 6, imagem 2 %32 Blackberry Curve 8310 Screen Housing Replacement: passo 6, imagem 3 %32
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. Blackberry Curve 8310 Screen Housing Replacement, Keyboard: passo 7, imagem 1 %32
    • Remove the keyboard.
  8. Blackberry Curve 8310 Screen Housing Replacement, Screen Housing: passo 8, imagem 1 %32
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. Blackberry Curve 8310 Screen Housing Replacement: passo 9, imagem 1 %32 Blackberry Curve 8310 Screen Housing Replacement: passo 9, imagem 2 %32
    • Now remove the left and right side panels.
  10. Blackberry Curve 8310 Screen Housing Replacement: passo 10, imagem 1 %32 Blackberry Curve 8310 Screen Housing Replacement: passo 10, imagem 2 %32 Blackberry Curve 8310 Screen Housing Replacement: passo 10, imagem 3 %32
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
Conclusão
Sean Willis
Membro desde: 01/26/12
229 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 10-32, Amido Winter 2012 Membro de Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,649
