Ir para o conteúdo principal
Blackberry Bold 9900 Power/Volume Button Replacement
O que você precisa
  1. Blackberry Bold 9900 Power/Volume Button Replacement, Battery: passo 1, imagem 1 %32
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Power/Volume Button Replacement: passo 2, imagem 1 %32
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Power/Volume Button Replacement, Mini-SIM removal: passo 3, imagem 1 %32
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Power/Volume Button Replacement, MicroSD card: passo 4, imagem 1 %32 Blackberry Bold 9900 Power/Volume Button Replacement, MicroSD card: passo 4, imagem 2 %32
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Power/Volume Button Replacement, Keyboard: passo 5, imagem 1 %32 Blackberry Bold 9900 Power/Volume Button Replacement, Keyboard: passo 5, imagem 2 %32
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Power/Volume Button Replacement: passo 6, imagem 1 %32 Blackberry Bold 9900 Power/Volume Button Replacement: passo 6, imagem 2 %32
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Power/Volume Button Replacement: passo 7, imagem 1 %32
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Power/Volume Button Replacement: passo 8, imagem 1 %32 Blackberry Bold 9900 Power/Volume Button Replacement: passo 8, imagem 2 %32
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Power/Volume Button Replacement, Back Case: passo 9, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Power/Volume Button Replacement: passo 10, imagem 1 %32
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
  11. Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: passo 11, imagem 1 %32 Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: passo 11, imagem 2 %32 Blackberry Bold 9900 Power/Volume Button Replacement, Power/Volume Button: passo 11, imagem 3 %32
    • Use the black nylon spudger to pop the press fit connector up from the lower left corner of the motherboard.
  12. Blackberry Bold 9900 Power/Volume Button Replacement: passo 12, imagem 1 %32
    • Lift the midframe, which contains the power/volume buttons, off of the motherboard and screen.
Conclusão
Uma outra pessoa concluiu este guia.
Sarah Westberg
Membro desde: 03/11/19
30.297 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
120 Membros
Autoria de 20.086 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 1,390
