Ir para o conteúdo principal
Blackberry Bold 9900 Memory Card Replacement
  1. Blackberry Bold 9900 Memory Card Replacement, Battery: passo 1, imagem 1 %32
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Memory Card Replacement: passo 2, imagem 1 %32
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Memory Card Replacement, MicroSD card: passo 3, imagem 1 %32 Blackberry Bold 9900 Memory Card Replacement, MicroSD card: passo 3, imagem 2 %32
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Memory Card Replacement, Mini-SIM removal: passo 4, imagem 1 %32
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
Conclusão
Uma outra pessoa concluiu este guia.
Sowmika
Membro desde: 01/30/18
253 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S1-G4, Johnson Spring 2018 Membro de Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 853
