Ir para o conteúdo principal
Blackberry Bold 9900 Keyboard Replacement
O que você precisa
  1. Blackberry Bold 9900 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Keyboard Replacement: passo 2, imagem 1 %32
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Keyboard Replacement, MicroSD card: passo 3, imagem 1 %32 Blackberry Bold 9900 Keyboard Replacement, MicroSD card: passo 3, imagem 2 %32
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Blackberry Bold 9900 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Keyboard Replacement: passo 5, imagem 1 %32 Blackberry Bold 9900 Keyboard Replacement: passo 5, imagem 2 %32
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Keyboard Replacement: passo 6, imagem 1 %32
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Keyboard Replacement: passo 7, imagem 1 %32 Blackberry Bold 9900 Keyboard Replacement: passo 7, imagem 2 %32
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Chris Velasquez
Membro desde: 01/30/18
214 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S1-G4, Johnson Spring 2018 Membro de Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 31
Últimos 30 dias: 39
Duração total: 1,730
