Ir para o conteúdo principal
Blackberry Bold 9650 Trackpad Replacement
O que você precisa
  1. Blackberry Bold 9650 Trackpad Replacement, Battery: passo 1, imagem 1 %32 Blackberry Bold 9650 Trackpad Replacement, Battery: passo 1, imagem 2 %32
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
    Pergunte ao FixBot
  2. Blackberry Bold 9650 Trackpad Replacement: passo 2, imagem 1 %32
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
    Pergunte ao FixBot
  3. Blackberry Bold 9650 Trackpad Replacement, SIM Card: passo 3, imagem 1 %32
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
    Pergunte ao FixBot
  4. Blackberry Bold 9650 Trackpad Replacement: passo 4, imagem 1 %32
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
    Pergunte ao FixBot
  5. Blackberry Bold 9650 Trackpad Replacement, Back Chassis: passo 5, imagem 1 %32
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
    Pergunte ao FixBot
  6. Blackberry Bold 9650 Trackpad Replacement: passo 6, imagem 1 %32
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
    Pergunte ao FixBot
  7. Blackberry Bold 9650 Trackpad Replacement: passo 7, imagem 1 %32
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
    Pergunte ao FixBot
  8. Blackberry Bold 9650 Trackpad Replacement: passo 8, imagem 1 %32
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
    Pergunte ao FixBot
  9. Blackberry Bold 9650 Trackpad Replacement, Mother Board: passo 9, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
    Pergunte ao FixBot
  10. Blackberry Bold 9650 Trackpad Replacement: passo 10, imagem 1 %32
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
    Pergunte ao FixBot
  11. Blackberry Bold 9650 Trackpad Replacement: passo 11, imagem 1 %32
    • Using a pair of tweezers, remove the three ribbon connectors.
    Pergunte ao FixBot
  12. Blackberry Bold 9650 Trackpad Replacement: passo 12, imagem 1 %32
    • Remove the mother board by lifting the board upward.
    Pergunte ao FixBot
  13. Blackberry Bold 9650 Trackpad Replacement, Faceplate: passo 13, imagem 1 %32 Blackberry Bold 9650 Trackpad Replacement, Faceplate: passo 13, imagem 2 %32
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
    Pergunte ao FixBot
  14. Blackberry Bold 9650 Trackpad Replacement, Trackpad: passo 14, imagem 1 %32
    • Using a plastic pry tool, lift and remove the three tabs securing the trackpad restrainer to the trackpad.
    Pergunte ao FixBot
  15. Blackberry Bold 9650 Trackpad Replacement: passo 15, imagem 1 %32
    • Flip the device over. The screen is facing upwards.
    • Remove the trackpad restrainer.
    Pergunte ao FixBot
  16. Blackberry Bold 9650 Trackpad Replacement: passo 16, imagem 1 %32
    • Slowly remove the trackpad by gently pulling the trackpad away from the device.
    • The ribbon cable attaching the trackpad to the mother board can break if the trackpad is pulled too quickly and forcefully.
    Pergunte ao FixBot
Conclusão
Ryan
Membro desde: 03/12/12
696 Reputação
Autoria de 11 guias
Equipe
Clemson, Team 2-5, Benson Spring 2012 Membro de Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 88
Ao todo: 6,517
