1. Turn the device upside down. Using your finger, slide the silver cover release button towards the top of the device.
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Using your fingernails, lift the sides of the battery.
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Orient the device so the screen is facing the ground.
    • Orient the device so the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Gently pull out the SIM card.
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
    • Using a T6 Torx Screwdriver, remove the four torx screws located on the bottom half of the device.
  6. Free shipping on all orders over US$100 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  7. Orient the device so that the screen is facing you.
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  8. Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
    • Using a T6 Torx Screwdriver, remove the two torx screws located in the top corners of the device.
  9. Remove the back chassis by gently pulling the chassis back and forth.
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
  10. Orient the device so the screen is facing the ground and the top of phone is facing you.
    • Orient the device so the screen is facing the ground and the top of phone is facing you.
    • Using a pair of tweezers, lift and remove the following:
    • The two round connectors on the top of the mother board.
    • The round connectors are hooked into the mother board.
    • The flat connector in the lower corner of the mother board.
  11. Using your fingers, carefully lift and remove the mother board.
    • Using your fingers, carefully lift and remove the mother board.
    • The connectors underneath the mother board are delicate and easily damaged.
  12. Using a pair of tweezers, remove the three ribbon connectors.
    • Using a pair of tweezers, remove the three ribbon connectors.
    • The ribbon cable connectors are delicate and easily damaged.
  13. Remove the mother board by lifting the board upward.
    • Remove the mother board by lifting the board upward.
  14. Using a pry tool, lift up on the four tabs located on the edges of the faceplate. Remove the faceplate by lifting the plate upward.
    • Using a pry tool, lift up on the four tabs located on the edges of the faceplate.
    • Remove the faceplate by lifting the plate upward.
  15. Turn the phone so it is facing up.
    • Turn the phone so it is facing up.
    • Use the plastic pry tool to gently pry out the screen.
    • The screen is glued to the phone so it may require some force to remove so use extra caution to prevent the screen from breaking.
  16. Lift the screen away from the device.
    • Lift the screen away from the device.
Conclusão
3 outras pessoas concluíram este guia.
Ryan
642 reputação
11 Guides authored
Equipe
Clemson, Team 2-5, Benson Spring 2012 Membro de Clemson, Team 2-5, Benson Spring 2012
CLEM-BENSON-S12S2G5
2 Membros
11 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Todo: 8,242
