Ir para o conteúdo principal
Blackberry Bold 9000 Volume Toggle Replacement
O que você precisa
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: passo 1, imagem 1 %32
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: passo 2, imagem 1 %32
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: passo 3, imagem 1 %32
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: passo 4, imagem 1 %32
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: passo 5, imagem 1 %32
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: passo 7, imagem 1 %32
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: passo 8, imagem 1 %32
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: passo 9, imagem 1 %32
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
Conclusão
Kelly
Membro desde: 01/18/12
566 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-17, Maness Winter 2012 Membro de Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 2,516
