Ir para o conteúdo principal
Blackberry Bold 9000 Trackball Replacement
O que você precisa
  1. Blackberry Bold 9000 Trackball Replacement, Battery: passo 1, imagem 1 %32
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Trackball Replacement: passo 2, imagem 1 %32
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Trackball Replacement: passo 3, imagem 1 %32
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Trackball Replacement, Rear Case: passo 4, imagem 1 %32
    • Remove the SIM card.
  5. Blackberry Bold 9000 Trackball Replacement: passo 5, imagem 1 %32
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Trackball Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Trackball Replacement, Trackball: passo 7, imagem 1 %32
    • Using the same plastic opening tool, lift out the motherboard assembly.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Trackball Replacement: passo 8, imagem 1 %32
    • Using a spudger, pry the top of the metal casing off. There are two pins holding it in place; it should pop off easily.
    • Repeat to the bottom.
    • This step requires pristine dexterity. Try to find a friend with smaller fingers if necessary.
  9. Blackberry Bold 9000 Trackball Replacement: passo 9, imagem 1 %32
    • Lift the trackball out of its socket.
Conclusão
5 outras pessoas executaram este guia.
Kelly
Membro desde: 01/18/12
566 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-17, Maness Winter 2012 Membro de Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 11,150
