Ir para o conteúdo principal
Blackberry Bold 9000 LCD Screen Replacement
O que você precisa
  1. Blackberry Bold 9000 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 LCD Screen Replacement: passo 2, imagem 1 %32
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 LCD Screen Replacement: passo 3, imagem 1 %32
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 LCD Screen Replacement, Rear Case: passo 4, imagem 1 %32
    • Remove the SIM card.
  5. Blackberry Bold 9000 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 LCD Screen Replacement: passo 6, imagem 1 %32
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32
    • With the same plastic opening tool, lift the motherboard up and out.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 LCD Screen Replacement: passo 8, imagem 1 %32
    • Using a spudger, lift the ribbon band in the upper right-hand corner up and away from the motherboard assembly until it disconnects.
  9. Blackberry Bold 9000 LCD Screen Replacement: passo 9, imagem 1 %32
    • Turn the motherboard assembly over.
    • Starting at the lower corners of the screen, begin to lift the screen away from the motherboard using the spudger.
    • Do this step very slowly to avoid breaking the screen or the motherboard. The backing will eventually separate.
    • Remove the plastic bit that hides the speaker grill - it is stuck with double-sided tape.
    • With a thin blade/pin, ease the speaker grill and the metal plate away from the old lcd screen.
Conclusão
8 outras pessoas executaram este guia.
Kelly
Membro desde: 01/18/12
566 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 8-17, Maness Winter 2012 Membro de Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 7,493
