Introdução
If the rear speaker on your Blackberry 7520 is broken, look here to install a new one.
Peças
Não são necessárias peças.
  1. Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone. Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone.
    • Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Use a pick or plastic iPod opening tool to push the clips, that are holding the rear casing. Apply a firm pressure at a forty-five degree angle to dislodge the clips. Applying too much pressure could break the plastic clips and permanently damage the casing, so be careful.
    • Use a pick or plastic iPod opening tool to push the clips, that are holding the rear casing. Apply a firm pressure at a forty-five degree angle to dislodge the clips.
    • Applying too much pressure could break the plastic clips and permanently damage the casing, so be careful.
  6. Repeat the  process of unlatching the clips for the top section of the Blackberry.
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  7. Do not try to pull the two pieces apart. You may tear the antenna cable.  Instead, fold the two pieces open to avoid stress on the cable.
    • Do not try to pull the two pieces apart. You may tear the antenna cable. Instead, fold the two pieces open to avoid stress on the cable.
  8. Separating the two halves allows you to access the speaker. Which is located in the front half of the case.
    • Separating the two halves allows you to access the speaker. Which is located in the front half of the case.
  9. Insert a plastic opening tool between the speaker and the case. Then pry the speaker out. To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture. To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture.
    • Insert a plastic opening tool between the speaker and the case. Then pry the speaker out.
    • To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture.
Conclusão
Nathan
31 reputação
6 Guides authored
Equipe
Cal Poly, Team 5-7, Forte Winter 2010 Membro de Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 2,374
