Ir para o conteúdo principal
Blackberry 7105t Speaker Replacement
O que você precisa
  1. Blackberry 7105t Speaker Replacement, Blackberry 7105t Disassembly: passo 1, imagem 1 %32
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Speaker Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Speaker Replacement: passo 3, imagem 1 %32
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Speaker Replacement: passo 4, imagem 1 %32
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Speaker Replacement: passo 5, imagem 1 %32 Blackberry 7105t Speaker Replacement: passo 5, imagem 2 %32 Blackberry 7105t Speaker Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Speaker Replacement: passo 6, imagem 1 %32
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Speaker Replacement: passo 7, imagem 1 %32
    • The black battery casing and logic board can now be separated for the following steps.
  8. Blackberry 7105t Speaker Replacement, Speaker: passo 8, imagem 1 %32 Blackberry 7105t Speaker Replacement, Speaker: passo 8, imagem 2 %32
    • With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
    • Place the three clips in plastic bag and set aside.
    • Once clips are removed, you will have full access to remove the speaker.
Conclusão
CeeJay
Membro desde: 10/28/09
19 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-17, Regan Fall 2009 Membro de Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,181
