Introdução
This guide will allow the user to replace the speaker.
O que você precisa
With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
With the speaker facing towards you, use a spudger to unfasten the three clips indicated in the picture.
Place the three clips in plastic bag and set aside.
Once clips are removed, you will have full access to remove the speaker.
Quase terminado!
Conclusão
