Pular para o conteúdo principal
Introdução
This guide is a single step that is a prerequisite for the screen and keyboard guides.
Peças
Nenhum componente especificado.
  1. With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Remove the battery by pushing against it from the right and then pulling towards you.
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  6. Use a plastic opening tool or your fingernails to remove the plastic backing. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated. Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  7. Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  8. The black battery casing and logic board can now be separated for the following steps.
    • The black battery casing and logic board can now be separated for the following steps.
  9. The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • The silver piece is not attached to the logic board in any way, and can be taken off by lifting it up with plastic opening tools.
    • Warning: Some of the phones have an adhesive between the silver part and the battery housing, so it could stick to the black piece you just removed.
Conclusão
CeeJay
Membro desde: 28-10-2009
19 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 9-17, Regan Fall 2009 Membro de Cal Poly, Team 9-17, Regan Fall 2009
CPSU-REGAN-F09S9G17
4 Membros
7 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 1,232
