Ir para o conteúdo principal
BlackBerry Z30 Middle Frame Replacement
O que você precisa
  1. BlackBerry Z30 Middle Frame Replacement, Battery cover: passo 1, imagem 1 %32
    • Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
  2. BlackBerry Z30 Middle Frame Replacement, Remove SIM and Media Card: passo 2, imagem 1 %32
    • Remove the SIM card and the Media SD card by pushing on them.
  3. BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: passo 3, imagem 1 %32 BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: passo 3, imagem 2 %32 BlackBerry Z30 Middle Frame Replacement, Unscrewing the LCD panel: passo 3, imagem 3 %32
    • Locate and unscrew all 10 T5 screws around the back cover
  4. BlackBerry Z30 Middle Frame Replacement, Separate the LCD from the Frame: passo 4, imagem 1 %32 BlackBerry Z30 Middle Frame Replacement, Separate the LCD from the Frame: passo 4, imagem 2 %32
    • Use Plastic opening tools to separate the LCD from the Main body
    • Do NOT remove the screen yet, it is attached with a very fragile ribbon to the main board.
    • Start on the same side of the Audio Jack
  5. BlackBerry Z30 Middle Frame Replacement, Remove the LCD: passo 5, imagem 1 %32 BlackBerry Z30 Middle Frame Replacement, Remove the LCD: passo 5, imagem 2 %32
    • Use a plastic tool to carefully switch up the LCD ribbon holder
    • Detach the LCD from the main board
    • When installing the new LCD, make sure the ribbon is inserted to the white line.
  6. BlackBerry Z30 Middle Frame Replacement, LCD Panel removal: passo 6, imagem 1 %32
    • You can now detach the LCD Panel from the main frame.
  7. BlackBerry Z30 Middle Frame Replacement, Untie the System board: passo 7, imagem 1 %32
    • With a plastic tool, untie the system board by detaching the ribbons attached to it
    • The battery ribbon is on the bottom right
    • Be gentle when detaching these Ribbons as they are very easy to tear and damage.
  8. BlackBerry Z30 Middle Frame Replacement, Untie the System board Part 2: passo 8, imagem 1 %32
    • Be gentle as any other system board ribbons, they are very easy to damage
  9. BlackBerry Z30 Middle Frame Replacement, Untie the system board Part 3: passo 9, imagem 1 %32
    • Power Button /Audio Jack
    • Flash
    • Rear Facing Camera
  10. BlackBerry Z30 Middle Frame Replacement, System board removal: passo 10, imagem 1 %32
    • Once all Ribbons untied, gently wiggle the system board out of the frame
    • Do not pull hard as there might be a ribbon on the way
  11. BlackBerry Z30 Middle Frame Replacement, Remove the Rear Camera: passo 11, imagem 1 %32 BlackBerry Z30 Middle Frame Replacement, Remove the Rear Camera: passo 11, imagem 2 %32
    • Use a pair of pliers to remove the rear facing camera
  12. BlackBerry Z30 Middle Frame Replacement, Remove the Battery: passo 12, imagem 1 %32 BlackBerry Z30 Middle Frame Replacement, Remove the Battery: passo 12, imagem 2 %32 BlackBerry Z30 Middle Frame Replacement, Remove the Battery: passo 12, imagem 3 %32
    • If this is the original battery, it might be hold down by VERY strong adhesive on the top, middle and bottom part. Be careful not to damage the battery
    • As pointed in the comments, be careful about the NFC membrane when removing the battery. Use heat to loosen the glue.
  13. BlackBerry Z30 Middle Frame Replacement, Replace the Middle Frame: passo 13, imagem 1 %32
    • Re-Assemble the unit using the new middle frame.
Conclusão
4 outras pessoas executaram este guia.
Hans
Membro desde: 10/20/14
1.926 Reputação
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 19
Ao todo: 3,916
