Introdução
This guide will allow you to safely replace the LCD panel of your BlackBerry Z30 unit.
O que você precisa
Remove the battery cover by grabbing the notch under the bottom speakers and lifting.
Remove the SIM card and the Media SD card by pushing on them.
Use Plastic opening tools to separate the LCD from the Main body
Use a plastic tool to carefully switch up the LCD ribbon holder
Detach the LCD from the main board
10 outras pessoas executaram este guia.
6Comentários do guia
This YouTube video by ItsmeJC also helped a lot.
https://www.youtube.com/watch?v=yISRs3lW...
I had difficulties when trying to re-insert and re-lock the ribbon in place, but it turned out that I overlooked and missed the fact that the ribbon should go under the ribbon holder, not between it and the "fixing switch". Otherwise, the procedure was a snap.
After screen replacement I'm having proximity sensor issues. screen is responsive and everything works good but its flashing on and off. disconnecting the proximity sensor fixes the issue but it's also the same connection as lock button so not an option. reinstalling original screen works as normal, new screen is original manufacture and has the same foam gaskets and uv filters as original around the prox sensor...
any thoughts?
Hi Andrew,
Beware, some sellers claims their screens are original but they are not. The few times the issue you have discribed occured to me where when the LCD unit was defective. Please arrange an exchange with your seller if you can. The fact that when you put back your shattered screen and it works is the proof that your new unit is defective.
Good luck.
Hans -
Pricing for the BlackBerry Z 30 screen? As well as the availability?
Are black berry screens available in Uganda
