Introdução
Use this guide to replace the motherboard on your BlackBerry Z10.
O que você precisa
Disconnect the logic board connector near the top and left side.
Underneath the connector on the left side, there's two other connectors. Disconnect those.
Remove the logic board and viola, you're done! Easiest repair in life!! To reassemble follow this guide in reverse. Happy repairing!
21 outras pessoas executaram este guia.
2 comentários
For what is the second Screwdriver and what size is the right on?
