Ir para o conteúdo principal
BlackBerry Z10 Battery Replacement
  1. BlackBerry Z10 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the phone over so that the back cover faces up.
    • Locate the groove at the bottom center of the phone.
    • Press the groove with your thumb to release the edge of the case from the phone.
  2. BlackBerry Z10 Battery Replacement: passo 2, imagem 1 %32 BlackBerry Z10 Battery Replacement: passo 2, imagem 2 %32
    • Use your thumb and index finger to carefully open the sides of the phone.
    • Start from the bottom and work your fingers up along the sides of the phone until the back cover is completely separated from the body of the phone.
  3. BlackBerry Z10 Battery Replacement: passo 3, imagem 1 %32 BlackBerry Z10 Battery Replacement: passo 3, imagem 2 %32 BlackBerry Z10 Battery Replacement: passo 3, imagem 3 %32
    • Lift the bottom corner of the battery with your fingers.
    • Remove the battery from the body of the phone.
Conclusão
6 outras pessoas executaram este guia.
Emie Lou Cruz
Membro desde: 09/08/14
1.054 Reputação
3 Guias de autoria
Equipe
CSU Fullerton, Team 1-2, Bruce Fall 2014 Membro de CSU Fullerton, Team 1-2, Bruce Fall 2014
CSUF-BRUCE-F14S1G2
3 Membros
4 Guias de autoria
Um comentário
Battery 🔋 full but in one minute to lower
And power off
Zezo1901 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 4,240
