Ir para o conteúdo principal
BlackBerry World Edition 8830 LCD Screen Replacement
O que você precisa
  1. BlackBerry World Edition 8830 LCD Screen Replacement, Battery: passo 1, imagem 1 %32 BlackBerry World Edition 8830 LCD Screen Replacement, Battery: passo 1, imagem 2 %32 BlackBerry World Edition 8830 LCD Screen Replacement, Battery: passo 1, imagem 3 %32
    • Before beginning this installation, make sure phone is powered off .
    • Turn phone over to the backside.
    • Press down on the lower portion of the back cover.
    • Slide the lower portion down to remove the cover and reveal the battery.
  2. BlackBerry World Edition 8830 LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the battery from the phone.
  3. BlackBerry World Edition 8830 LCD Screen Replacement, Front and Back Casing: passo 3, imagem 1 %32 BlackBerry World Edition 8830 LCD Screen Replacement, Front and Back Casing: passo 3, imagem 2 %32
    • Once the battery is removed, remove the four 9.2 mm screws with the T4 Torx Screwdriver.
  4. BlackBerry World Edition 8830 LCD Screen Replacement: passo 4, imagem 1 %32 BlackBerry World Edition 8830 LCD Screen Replacement: passo 4, imagem 2 %32 BlackBerry World Edition 8830 LCD Screen Replacement: passo 4, imagem 3 %32
    • Remove side panels with the Plastic Opening Tool by sliding it along the edge of the panel until you can pry it off with the tool.
  5. BlackBerry World Edition 8830 LCD Screen Replacement: passo 5, imagem 1 %32 BlackBerry World Edition 8830 LCD Screen Replacement: passo 5, imagem 2 %32
    • Remove the back casing using the Plastic Opening Tool
    • Once the back casing is removed the top two buttons are likely to pop out.
  6. BlackBerry World Edition 8830 LCD Screen Replacement: passo 6, imagem 1 %32 BlackBerry World Edition 8830 LCD Screen Replacement: passo 6, imagem 2 %32 BlackBerry World Edition 8830 LCD Screen Replacement: passo 6, imagem 3 %32
    • Locate the two 9.2mm screws on the upper inside casing
    • Remove them using the T4 Torx Screwdriver
    • Slide off the front casing once the screws are removed.
    • Trackball will fall out once the casing is removed.
  7. BlackBerry World Edition 8830 LCD Screen Replacement, LCD Screen: passo 7, imagem 1 %32 BlackBerry World Edition 8830 LCD Screen Replacement, LCD Screen: passo 7, imagem 2 %32 BlackBerry World Edition 8830 LCD Screen Replacement, LCD Screen: passo 7, imagem 3 %32
    • Disconnect the tab attached to the interior casing from the LCD Screen by gently pulling the tab up and away from the phone.
    • Use the Plastic Opening Tool to pry the LCD Screen out.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 17-27, Amido Spring 2012 Membro de Cal Poly, Team 17-27, Amido Spring 2012
CPSU-AMIDO-S12S17G27
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 469
