Ir para o conteúdo principal
BlackBerry Torch 9850 Display Replacement
O que você precisa
  1. BlackBerry Torch 9850 Display Replacement, Display: passo 1, imagem 1 %32 BlackBerry Torch 9850 Display Replacement, Display: passo 1, imagem 2 %32 BlackBerry Torch 9850 Display Replacement, Display: passo 1, imagem 3 %32
    • Remove the battery.
    • Use a plastic spudger tool or your fingers to gently pop the battery out from the bottom by pushing and lifting.
  2. BlackBerry Torch 9850 Display Replacement: passo 2, imagem 1 %32 BlackBerry Torch 9850 Display Replacement: passo 2, imagem 2 %32 BlackBerry Torch 9850 Display Replacement: passo 2, imagem 3 %32
    • Removing the sim card.
    • Press and pull down on the yellow tab until the sim card falls out.
  3. BlackBerry Torch 9850 Display Replacement: passo 3, imagem 1 %32 BlackBerry Torch 9850 Display Replacement: passo 3, imagem 2 %32 BlackBerry Torch 9850 Display Replacement: passo 3, imagem 3 %32
    • Remove the plastic bezle.
    • To remove the plastic bezle on the back of the phone, use a plastic prying tool to gently pry it off.
    • Begin in the center on the bottom of the phone, and slowly work your way around to each side.
    • Once the bezle is loosened on both sides, you can gently pull it off with your hands.
  4. BlackBerry Torch 9850 Display Replacement: passo 4, imagem 1 %32 BlackBerry Torch 9850 Display Replacement: passo 4, imagem 2 %32 BlackBerry Torch 9850 Display Replacement: passo 4, imagem 3 %32
    • Remove the screws.
    • You will need to remove the ten small screws that hold the back of the phone together.
    • Start by using a T5 phillips screw driver to remove the four 4.5 mm screws on the outside corners of the phone.
    • Next, use a T4 phillips screw driver to remove the four 4mm screws on the sides of the device.
    • Lastly, use the T4 phillips screw driver again to remove the last of the screws, which should be two 2mm screws on the bottom.
  5. BlackBerry Torch 9850 Display Replacement: passo 5, imagem 1 %32 BlackBerry Torch 9850 Display Replacement: passo 5, imagem 2 %32
    • Remove the back piece.
    • Once you have all the screws removed, gently remove the back piece of the phone with your hands.
    • Do not pull the back of the phone all the way off, because there are cable ribbons that will break if you do.
  6. BlackBerry Torch 9850 Display Replacement: passo 6, imagem 1 %32 BlackBerry Torch 9850 Display Replacement: passo 6, imagem 2 %32
    • Disconnect the main cable ribbon.
    • There will be a black cable ribbon on the upper right side of the phone.
    • Using the metal pry tool, gently pry this cable ribbon open to separate the front and back pieces of the phone.
  7. BlackBerry Torch 9850 Display Replacement: passo 7, imagem 1 %32 BlackBerry Torch 9850 Display Replacement: passo 7, imagem 2 %32 BlackBerry Torch 9850 Display Replacement: passo 7, imagem 3 %32
    • Disconnect the remaining cable ribbons.
    • There are two copper cable ribbons.
    • Using a metal pry tool, carefully disconnect the first copper cable ribbon on the bottom right side of the phone.
    • Likewise, disconnect the square copper cable ribbon at the top right of the phone.
    • Once you disconnect the first square cable ribbon, a second will be exposed and you can disconnect that one the same way.
  8. BlackBerry Torch 9850 Display Replacement: passo 8, imagem 1 %32 BlackBerry Torch 9850 Display Replacement: passo 8, imagem 2 %32 BlackBerry Torch 9850 Display Replacement: passo 8, imagem 3 %32
    • Remove the LCD screen.
    • Once you have completed all of the previous steps, you can remove the display.
    • Gently pry on the little tab at the top of the screen to remove it.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 26
Ao todo: 742
