Ir para o conteúdo principal
BlackBerry Storm 9530 Logic/Motherboard Replacement
O que você precisa
  1. BlackBerry Storm 9530 Logic/Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Have a cracked screen? Need to replace your speaker? Etc? Well just follow these steps.
  2. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 2, imagem 1 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 2, imagem 2 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 2, imagem 3 %32
    • Turn your Storm where the battery door is facing up.
    • Remove the battery door.
    • Remove the battery.
  3. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the two hex screws as shown by the SIM card slot.
  4. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 4, imagem 1 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the plastic piece that covers the camera & flash on the back . This is held in with some tape so use a safe pry tool.
    • Remove the two hex screws underneath it.
  5. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 5, imagem 1 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 5, imagem 2 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 5, imagem 3 %32
    • Turn the phone over and remove the plastic cover under the buttons as shown.
    • Remove the 2 screws underneath.
  6. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 6, imagem 1 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 6, imagem 2 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 6, imagem 3 %32
    • Go around your device with the plastic pry tool, there a 3 clips on each side of the housing.
    • There is a connection for the antenna from the front to mid housing. Remove it with a pry tool if it does not come off by itself.
  7. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 7, imagem 1 %32
    • You now have 3 pieces. The rear, mid , & front housing.
  8. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 8, imagem 1 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 8, imagem 2 %32
    • To remove the screen gently pry up this ribbon cable with a pry tool.
  9. BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 9, imagem 1 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 9, imagem 2 %32 BlackBerry Storm 9530 Logic/Motherboard Replacement: passo 9, imagem 3 %32
    • To remove the main board from the mid housing disconnect the ribbon cable as pictured.
    • Now follow in reverse order for reassembly!
Conclusão
6 outras pessoas executaram este guia.
Josh Forester
Membro desde: 11/28/10
2.497 Reputação
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 9,550
