Pular para o conteúdo principal
Introdução
Follow this guide to remove the logic board.
Peças
Nenhum componente especificado.
  1. Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
    • Use a T9 Screwdriver to unscrew the two screws on the backside of the BlackBerry, one on the bottom left and one on the top right.
  2. Remove the backside of the device and set aside for later use.
    • Remove the backside of the device and set aside for later use.
  3. Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage. Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
    • Remove the rubber placement pad that sits under the battery and set aside for later use. Gently fold back the battery, making sure the small plug connecting the battery to the logic board remains intact. Extra care should be taken as this part is quite delicate and easy to damage.
  4. Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
    • Use the T9 Screwdriver to remove the five visible screws: Top right, bottom right, middle center, bottom center, bottom left.
  5. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break. Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • Carefully remove the board from the device by gently pushing on the screen from the front side. The battery, screen, and scroll wheel are all connected to the logic board. Be sure to support these components so they do not break.
    • Note the placement of two additional rubber pieces that cling loosely to the logic board. It is okay to let these pieces fall loose.
    • One is located below the scrollwheel.
    • Another is located behind the screen.
  7. Pinch the white plastic clip that connects the ribbon of the scroll wheel to the logic board. Gently wiggle and pull upwards to remove the scroll wheel.
    • Pinch the white plastic clip that connects the ribbon of the scroll wheel to the logic board.
    • Gently wiggle and pull upwards to remove the scroll wheel.
  8. Pull out the two black clips securing the screen’s ribbon so that they are as far out as they will go. Gently remove the screen’s ribbon from the slot. Be sure to support the screen and any connected parts.
    • Pull out the two black clips securing the screen’s ribbon so that they are as far out as they will go.
    • Gently remove the screen’s ribbon from the slot. Be sure to support the screen and any connected parts.
  9. Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
    • Disconnect the power conductor by gently peeling the grey section (which is connected to the logic board) upwards.
  10. The conductor can now be easily removed by pulling it off of the logic board.
    • The conductor can now be easily removed by pulling it off of the logic board.
  11. Gently pull on the wires connecting the battery to the device until the battery disconnects. Gently pull on the wires connecting the battery to the device until the battery disconnects.
    • Gently pull on the wires connecting the battery to the device until the battery disconnects.
Conclusão
Steven Jackowski
Membro desde: 18-04-2010
1 reputação
7 Guias de autoria
Equipe
Cal Poly, Team 33-83, Johann Spring 2010 Membro de Cal Poly, Team 33-83, Johann Spring 2010
CPSU-JOHANN-S10S33G83
4 Membros
7 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Todo: 1,035
