Ir para o conteúdo principal
BlackBerry PlayBook Speaker Replacement
O que você precisa
  1. BlackBerry PlayBook Speaker Replacement, Remove Back Panel: passo 1, imagem 1 %32 BlackBerry PlayBook Speaker Replacement, Remove Back Panel: passo 1, imagem 2 %32
    • Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
    • There are clips that need to be released on all four sides of the device.
    • When replacing the back cover insert the bottom side first ( usb and hdmi ports stick out about 2mm ) inserting them into the covers openings will allow for easier reassembly
  2. BlackBerry PlayBook Speaker Replacement, Unscrew Left Speaker: passo 2, imagem 1 %32
    • Remove 1.55x.33mm Phillips screw from the metal frame.
    • Remove 1.5x4.25mm Phillips screw from speaker bar.
  3. BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: passo 3, imagem 1 %32 BlackBerry PlayBook Speaker Replacement, Remove the Left Speaker Stickers: passo 3, imagem 2 %32
    • Peel off the stickers holding the left speaker in place with a tweezer or by using your fingers
  4. BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: passo 4, imagem 1 %32 BlackBerry PlayBook Speaker Replacement, Remove Left Speaker: passo 4, imagem 2 %32
    • Slide the left speaker bar out from its metal bracket.
  5. BlackBerry PlayBook Speaker Replacement, Unscrew Right Speaker: passo 5, imagem 1 %32
    • Remove both 1.5x4.25mm Phillips screws from the right speaker bar by using the Phillips Screwdriver.
  6. BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: passo 6, imagem 1 %32 BlackBerry PlayBook Speaker Replacement, Remove Right Speaker: passo 6, imagem 2 %32
    • Lift the right speaker bar to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Nathan
Membro desde: 10/12/14
661 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-27, Maness Fall 2014 Membro de Cal Poly, Team 14-27, Maness Fall 2014
CPSU-MANESS-F14S14G27
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 972
