Introdução
Many components of a tablet cannot be safely replaced individually, such as the CPU. Instead, you will likely want to replace the motherboard as a single unit.
O que você precisa
Use a plastic opening tool to pry the back panel off by inserting it in between the front and back panel.
Remove the battery connector using either your fingers or a pair of tweezers.
With the spudger, remove the flat-top connector coming from underneath the motherboard.
Remove the clipped ZIF data connector coming from underneath the motherboard.
Lift up the black plastic clip with a spudger.
Pull the connector out gently using tweezers.
Remove the following five screws from the motherboard.
Three 1.5x2.5mm Phillips screws
Two 1.55x2.38mm Phillips screws
Lift all four antenna connectors from the motherboard again using the spudger.
Gently lift the motherboard away from the device. If there is any resistance, check the previous steps to ensure that all connections have been removed.
7 outras pessoas executaram este guia.
