Ir para o conteúdo principal
BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball
O que você precisa
  1. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: passo 1, imagem 1 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: passo 1, imagem 2 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball, Circuit Board and Roller Ball: passo 1, imagem 3 %32
    • Remove four screws total on the back of the phone casing near edge of battery area.
    • Two screws that are closer to the top of the phone are protected by plastic stoppers. Remove them then remove the screws.
    • There are two more screws on either side of where the battery was located. remove them as well.
  2. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 2, imagem 1 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 2, imagem 2 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 2, imagem 3 %32
    • Remove the bottom plastic piece.
    • This may require prying from a few different directions. The plastic blue prying tool featured here may be required.
  3. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 3, imagem 1 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 3, imagem 2 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 3, imagem 3 %32
    • Once the keypad is removed, the buttons on the sides of the phone will fall out.
    • You will need to loosen the board from the right side opposite the charging ports.
    • Pull gently towards the right side so the ports clear the plastic casing.
    • Gently flip the board over to the left.
  4. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 4, imagem 1 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 4, imagem 2 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 4, imagem 3 %32
    • On the back of the circuit board you will find a small rectangular blue piece with a black 'L' shape in the middle.
    • Gently detach this from the back of the main board.
    • Now you may fully remove the main board.
  5. BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 5, imagem 1 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 5, imagem 2 %32 BlackBerry Pearl Flip 8220 Circuit Board and Roller Ball: passo 5, imagem 3 %32
    • What is left inside the phone is the roller ball.
    • Gently use the plastic blue tool to detach it from the frame.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley
Membro desde: 04/15/13
318 Reputação
Autoria de 3 guias
Equipe
SUNY Cortland, Team 1-5, Getto Spring 2013 Membro de SUNY Cortland, Team 1-5, Getto Spring 2013
SUNYCORT-GETTO-S13S1G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 795
