Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Looking at the battery of your phone can help solve a multitude of problems. By removing the back of your phone you can access the battery to your Blackberry Pearl.
  1. Flip the phone over to the back. Pull down on the small silver button at the bottom of the phone. The back of the phone will pop open.
    • Flip the phone over to the back.
    • Pull down on the small silver button at the bottom of the phone.
    • The back of the phone will pop open.
    • Remove the back of the phone.
  2. You will then be looking at the battery. To remove the battery, pull down on the top of the battery and pull it toward yourself. To remove the battery, pull down on the top of the battery and pull it toward yourself.
    • You will then be looking at the battery.
    • To remove the battery, pull down on the top of the battery and pull it toward yourself.
  3. To check for water damage look at the bottom of the phone battery.
    • To check for water damage look at the bottom of the phone battery.
    • In this image, the orange rectangle indicates water damage.
    • If the rectangle is white, there is no water damage.
Conclusão
Uma outra pessoa concluiu este guia.
Ashley
Membro desde: 15/04/2013
306 Reputação
3 Guias de autoria
Equipe
SUNY Cortland, Team 1-5, Getto Spring 2013 Membro de SUNY Cortland, Team 1-5, Getto Spring 2013
SUNYCORT-GETTO-S13S1G5
3 Membros
3 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,141
