Introdução
Use this repair guide to install the screen in the Blackberry Pearl 8100
O que você precisa
Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
After removing the logic board, place spudger between the logic board and screen and remove the screen, sliding it slowly away.
