Ir para o conteúdo principal
BlackBerry Pearl 8100 Keyboard Replacement
O que você precisa
  1. BlackBerry Pearl 8100 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Before working on the phone, be sure that the device is turned off.
    • Begin by removing the back panel; this can be done by pressing the silver button on the backside of the Blackberry 8100, while simultaneously sliding the back panel off.
    • Remove the battery located directly below back panel.
  2. BlackBerry Pearl 8100 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • Using a 1.5 mm Hex screwdriver, remove the two screws that hold the two panels together.
  3. BlackBerry Pearl 8100 Keyboard Replacement: passo 4, imagem 1 %32 BlackBerry Pearl 8100 Keyboard Replacement: passo 4, imagem 2 %32
    • Using the spudger, pry off the small portion of the casing located at the bottom of the phone.
  4. BlackBerry Pearl 8100 Keyboard Replacement: passo 5, imagem 1 %32
    • Using the spudger, pry off the side casings one at a time by wedging it between the inner casing and the sides.
  5. BlackBerry Pearl 8100 Keyboard Replacement: passo 6, imagem 1 %32
    • Using a 1.5mm Hex screwdriver, unscrew the two screws, located on the front of the phone, that connect the back and front panels.
  6. BlackBerry Pearl 8100 Keyboard Replacement: passo 7, imagem 1 %32 BlackBerry Pearl 8100 Keyboard Replacement: passo 7, imagem 2 %32
    • Using the spudger, pry off the back body panel by wedging the spudger in between the front and back panels on the side face. Remove the back body panel.
  7. BlackBerry Pearl 8100 Keyboard Replacement: passo 8, imagem 1 %32
    • Separate the logic board from the front panel.
  8. BlackBerry Pearl 8100 Keyboard Replacement: passo 9, imagem 1 %32 BlackBerry Pearl 8100 Keyboard Replacement: passo 9, imagem 2 %32
    • Gently remove the keyboard from front casing. It should snap out of place.
Conclusão
Uma outra pessoa concluiu este guia.
Robert Cronin
Membro desde: 04/08/10
544 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 34-57, Forte Spring 2010 Membro de Cal Poly, Team 34-57, Forte Spring 2010
CPSU-FORTE-S10S34G57
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 5,454
