Ir para o conteúdo principal
BlackBerry KeyONE partial Disassembly
O que você precisa
  1. BlackBerry KeyONE partial Disassembly, Remove top cover: passo 1, imagem 1 %32
    • Carefully remove the top plastic cover. It is held in place by adhesive.
    Pergunte ao FixBot
  2. BlackBerry KeyONE partial Disassembly, Remove top frame: passo 2, imagem 1 %32 BlackBerry KeyONE partial Disassembly, Remove top frame: passo 2, imagem 2 %32
    • Remove the two Philipps #0 screws that hold in place the top of the phone frame and slide it off.
    Pergunte ao FixBot
  3. BlackBerry KeyONE partial Disassembly, Remove back cover: passo 3, imagem 1 %32
    • Remove the back cover. It mostly just clips off, but has some adhesive in the lower area.
    Pergunte ao FixBot
  4. BlackBerry KeyONE partial Disassembly, Disconnect Battery: passo 4, imagem 1 %32 BlackBerry KeyONE partial Disassembly, Disconnect Battery: passo 4, imagem 2 %32
    • Remove the two Philipps #0 screws securing the battery connector and unplug the later.
    Pergunte ao FixBot
  5. BlackBerry KeyONE partial Disassembly: passo 5, imagem 1 %32
    • Remove the 6 Philipps #0 screws securing the lower cover and remove it.
    • Remove the three Philipps #0 screws holding down the bar that secures the two main lego-style plugs and remove it.
    Pergunte ao FixBot
  6. BlackBerry KeyONE partial Disassembly, Remove top cover: passo 6, imagem 1 %32
    • Remove the three Philipps #0 screws securing the upper cover and remove it.
    Pergunte ao FixBot
  7. BlackBerry KeyONE partial Disassembly: passo 7, imagem 1 %32
    • Unplug the remaining ribbon cables
    • Remove the last three Philipps #0 screws securing the Motherbard.
    • Now you should be able to replace most components.
    • The screen is held in place from the front by adhesive (or not, in the earlier versions), its cable slides trough the phone to the PCB - It's the large connector in the middle.
    • The battery is glued to the frame firmly. There are three pultabs located underneath the motherboard.
    • Don't forget to remove the sim-tray if you're removing the motherboard.
    Pergunte ao FixBot
Conclusão
15 outras pessoas executaram este guia.
raven
Membro desde: 09/02/15
1.110 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 77
Ao todo: 10,821
