Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
  1. Remove battery cover and battery on the back of the device.
    • Remove battery cover and battery on the back of the device.
  2. Using a small plastic opening tool, remove the lower rear cover.
    • Using a small plastic opening tool, remove the lower rear cover.
  3. Remove six screws from the midframe of the device.
    • Remove six screws from the midframe of the device.
  4. Remove the midframe from the phone.
    • Remove the midframe from the phone.
  5. Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Gently pry the back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case until the tabs until the motherboard comes free.
  6. Remove the screen so as not to damage it. Remove the screen so as not to damage it.
    • Remove the screen so as not to damage it.
  7. Carefully unhook the antenna cable in all three locations. Carefully unhook the antenna cable in all three locations.
    • Carefully unhook the antenna cable in all three locations.
  8. Detach the ribbon cable on the front of the motherboard.
    • Detach the ribbon cable on the front of the motherboard.
  9. Tilt the motherboard up and detach both ribbon connections.
    • Tilt the motherboard up and detach both ribbon connections.
  10. Replace the entire motherboard to replace the microphone (circled in red). Replace the entire motherboard to replace the microphone (circled in red).
    • Replace the entire motherboard to replace the microphone (circled in red).
Conclusão
Uma outra pessoa concluiu este guia.
Johnny Tran
Membro desde: 10-09-2011
473 Reputation
4 Guias de autoria
Equipe
Cuesta, Team 1-3, Zipperian Fall 2011 Membro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 Membros
8 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,110
