Introdução
Few tools are required to do this.
A small plastic pry tool or even a fingernail is sufficient. Working area surface should be clean and dry with adequate lighting.
Immediately wash hands after handling the battery and completing the process. Discard the dead battery properly.
Set aside the old battery, then replace it with the new battery. It should easily fit into place. Then, you can replace the backing of phone, pressing gently to secure it down.
Uma outra pessoa concluiu este guia.
