Ir para o conteúdo principal
BlackBerry Curve 8900 Antenna Replacement
O que você precisa
  1. BlackBerry Curve 8900 Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover of the phone.
    • The battery will now be visible.
  2. BlackBerry Curve 8900 Antenna Replacement: passo 2, imagem 1 %32 BlackBerry Curve 8900 Antenna Replacement: passo 2, imagem 2 %32
    • Pinch the battery at the grey semi-circles on the top left and top right corners of the battery using your fingers and remove it from the device.
  3. BlackBerry Curve 8900 Antenna Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove the lower rear cover, using a small iFixit opening tool.
  4. BlackBerry Curve 8900 Antenna Replacement: passo 4, imagem 1 %32
    • Remove the six screws from the mid-frame of the device, using the T6 Torx Screwdriver.
    • Set the screws aside once they've been removed.
  5. BlackBerry Curve 8900 Antenna Replacement: passo 5, imagem 1 %32
    • Gently remove the mid-frame from the phone, exposing the motherboard.
    • This is the motherboard.
  6. BlackBerry Curve 8900 Antenna Replacement: passo 6, imagem 1 %32 BlackBerry Curve 8900 Antenna Replacement: passo 6, imagem 2 %32
    • Gently pull back the plastic tabs that secure the motherboard to the case.
    • Slowly pull the tabs, working your way around the case, until they are lifted and the motherboard is free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall off the motherboard.
  7. BlackBerry Curve 8900 Antenna Replacement: passo 7, imagem 1 %32 BlackBerry Curve 8900 Antenna Replacement: passo 7, imagem 2 %32
    • Carefully detach the antenna from the two clips on the side of the motherboard.
    • Disconnect the antenna from the motherboard in the same manner.
  8. BlackBerry Curve 8900 Antenna Replacement: passo 8, imagem 1 %32
    • Carefully disconnect the ribbon cable located on the bottom right of the motherboard.
  9. BlackBerry Curve 8900 Antenna Replacement: passo 9, imagem 1 %32 BlackBerry Curve 8900 Antenna Replacement: passo 9, imagem 2 %32
    • Locate the chip underneath the screen.
    • Gently remove the screen, without applying too much pressure, taking care not to damage it.
  10. BlackBerry Curve 8900 Antenna Replacement: passo 10, imagem 1 %32 BlackBerry Curve 8900 Antenna Replacement: passo 10, imagem 2 %32
    • Lift up the motherboard from the bottom edge to reveal the ribbon cables.
    • Carefully disconnect the two ribbon cables connecting the motherboard to the display on either side.
    • Remove the motherboard and place off to the side.
  11. BlackBerry Curve 8900 Antenna Replacement, Antenna: passo 11, imagem 1 %32
    • Replace the entire center piece of the case to replace the antenna.
Conclusão
Once all the steps have been completed, reassemble the device in reverse order.
Johnny Tran
Membro desde: 09/10/11
473 Reputação
Autoria de 4 guias
Equipe
Cuesta, Team 1-3, Zipperian Fall 2011 Membro de Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 5,852
