Ir para o conteúdo principal
BlackBerry Curve 8520 Motherboard Replacement
O que você precisa
  1. BlackBerry Curve 8520 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. BlackBerry Curve 8520 Motherboard Replacement, Battery: passo 2, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement, Battery: passo 2, imagem 2 %32
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
  3. BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: passo 3, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement, Keyboard Cover: passo 3, imagem 2 %32
    • Remove the two Torx T6 screws to the left and right of the battery.
  4. BlackBerry Curve 8520 Motherboard Replacement: passo 4, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement: passo 4, imagem 2 %32
    • Using hairdryer or heat gun, warm the front panel to soften the adhesive beneath.
    • Starting from one side, use a plastic opening tool to pry up the screen cover.
    • Work carefully to avoid bending the screen cover.
    • Once one side is loose, gently peel up the entire cover.
  5. BlackBerry Curve 8520 Motherboard Replacement: passo 5, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement: passo 5, imagem 2 %32 BlackBerry Curve 8520 Motherboard Replacement: passo 5, imagem 3 %32
    • Insert the plastic opening tool in the seam along the side of the device.
    • Slide the tool along the length of the seam, applying moderate force with the plastic opening tool.
    • Carefully remove the faceplate.
  6. BlackBerry Curve 8520 Motherboard Replacement: passo 6, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement: passo 6, imagem 2 %32 BlackBerry Curve 8520 Motherboard Replacement: passo 6, imagem 3 %32
    • Remove four T6 Torx screws from the front of the phone.
    • Using tweezers, remove the keyboard buttons from the phone.
    bb is nt a freely phone is a phone bcz of ringing some how it is nt
    tankiso - Responder
  7. BlackBerry Curve 8520 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the two T6 Torx screws securing the small plastic bracket at the bottom of the phone.
    • Remove the four T6 Torx screws from the corners of the keyboard.
  8. BlackBerry Curve 8520 Motherboard Replacement: passo 8, imagem 1 %32 BlackBerry Curve 8520 Motherboard Replacement: passo 8, imagem 2 %32
    • Using a plastic opening tool, gently pry the motherboard assembly from the device's frame.
Conclusão
32 outras pessoas executaram este guia.
Matt
Membro desde: 04/07/11
1.722 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-62, Walters Spring 2011 Membro de Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
Membros da 5
Autoria de 5 guias
Um comentário
hi sir can u provide me the dead 8520 cuvre mobile phone
hunkerbhullar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 36,784
