Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Remove the battery of the BlackBerry Curve 8520.
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Insert a plastic opening tool into the small notch on the rear cover of the phone. Pry the rear cover up from the phone.
    • Insert a plastic opening tool into the small notch on the rear cover of the phone.
    • Pry the rear cover up from the phone.
  2. Locate the slit between the top of the battery and the casing. Gently apply pressure on the top of the battery to trigger the spring release.
    • Locate the slit between the top of the battery and the casing.
    • Gently apply pressure on the top of the battery to trigger the spring release.
Conclusão
8 outras pessoas concluíram este guia.
Matt
Membro desde: 07/04/2011
1.716 Reputação
5 Guias de autoria
Equipe
Cal Poly, Team 9-62, Walters Spring 2011 Membro de Cal Poly, Team 9-62, Walters Spring 2011
CPSU-WALTERS-S11S9G62
5 Membros
5 Guias de autoria
very clear instructions
mirandaseagrave - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 13,117
