Introdução
Remove the battery of the BlackBerry Curve 8520.
O que você precisa
Insert a plastic opening tool into the small notch on the rear cover of the phone.
Pry the rear cover up from the phone.
Locate the slit between the top of the battery and the casing.
Gently apply pressure on the top of the battery to trigger the spring release.
8 outras pessoas executaram este guia.
