Introdução
The process of replacing the trackpad of your BlackBerry Bold 9700 will allow you to become familiar with your device and restore full functionality.
O que você precisa
Remove the battery by prying the bottom of the battery upward.
Once the battery is angled up, pull it away from the top of the device.
Flip the board over so that the LCD display is against the the surface of your work space.
Use a plastic opening tool to gently remove the ribbon connector located on the right-hand side of the board.
3 outras pessoas executaram este guia.
