Introdução
This guide will demonstrate how to remove the trackball on a BlackBerry 8820. To reassemble the device, please follow the instructions provided in reverse order.
Always exercise caution when handling electronic components.
Peças
Não são necessárias peças.
  1. Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
    • Remove the battery cover by applying pressure and sliding down the silver square on the back of the phone.
  2. Remove the battery by prying under it with your finger or the plastic opening tool. Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
    • Remove the battery by prying under it with your finger or the plastic opening tool.
    • Remove the four small 3/8" long screws using a 1/16" diameter torx screwdriver.
  3. Use a nylon spudger to carefully remove the two side bars of plastic. Use a nylon spudger to carefully remove the two side bars of plastic.
    • Use a nylon spudger to carefully remove the two side bars of plastic.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Use a nylon spudger to carefully pry the back casing off.
    • Use a nylon spudger to carefully pry the back casing off.
      • There are two small clamps on each edge that need to be unhooked before the casing will come off.
  6. Pry off the front casing.
    • Pry off the front casing.
      • Be aware of sensors and other sensitive areas of the newly exposed electronics.
  7. After removing the front from the outer casing, the track ball will come off attached to the casing.
    • After removing the front from the outer casing, the track ball will come off attached to the casing.
  8. Remove the track ball from the front case.
    • Remove the track ball from the front case.
Conclusão
3 outras pessoas concluíram este guia.
ryan
41 reputação
5 Guides authored
Equipe
Cal Poly, Team 13-64, Johann Spring 2013 Membro de Cal Poly, Team 13-64, Johann Spring 2013
CPSU-JOHANN-S13S13G64
4 Membros
7 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 686
